grizzly wheel wobble
Take the brake caliper off and get it out of the way (disc can stay on the hub). Remove center nut and slide the hub off of the spindle. Inspect/replace bearings/seals.
At 200 miles, I don't think that it bearings. Maybe just loose center nut. Look everything over closely (ball joints, bushings). Make sure to correct the problem before any riding. Good luck.
Sorry about that. For some reason, I was thinking of a 2wd.
Anyway on yours, the CV joint is the spindle. Take the center nut off and you will need to remove the knuckle from ball joint/strut. I believe Grizz uses stuts. The ball joints can be removed by loosening the nut and tapping on the nut/thread shaft (leave nut on while tapping so u don't damage the threads.)
Elkaholic
Sep 6, 2015 02:44 PM
