Problem with a wider Banshee !!!!
Old Aug 8, 2001 | 06:41 PM
sparky2001's Avatar
I bought a pair of wheel spacers for my Banshee. The problem is that I donīt know how to take out the stock stud from the hubs.
Do I have to hit them with a hammer or just unscrew them.
If I have to unscrew them from the hubs, How do I do this ??
Thanks !!!
Old Aug 8, 2001 | 08:15 PM
Joey9's Avatar
There splined and press fit, just like a car. Hopefully you have an extra nut that will fit that you don't mind messing up. Put the nut on the end of the stud. Screw it on almost flush with the end of the stud (nut being a little higher off the stud) and hammer it out. Just be careful. Later
Old Aug 9, 2001 | 07:18 PM
sparky2001's Avatar
Thanks. I will try that !!!
Old Aug 10, 2001 | 12:05 AM
lonestarbanshee's Avatar
If you mess up the nut, you can always buy replacements from Ronnies for $.62 Just in Case [img]i/expressions/face-icon-small-wink.gif[/img]
Old Aug 10, 2001 | 04:15 PM
MIA416EX's Avatar
Hey, so I too just got a set of easy-fit wheelspacers for the front of my 400EX...
Have you guys ever tried them on the rear tires? I heard somewhere that the rear wheel spacers can fail due to the load put on them by the driving rear tires....true? or no?
$80 for a set of rear spacers is a bit easier to swallow than $350 for a +2" lone-star axle...
Old Aug 10, 2001 | 06:53 PM
sparky2001's Avatar
Thanks you all. I think I will have to take the hub out of the axel to hammer on th studs.
Old Aug 11, 2001 | 11:51 PM
Zorro's Avatar
Just curious...when replacing the studs, do you put back new longer studs or is it a bolt that you have to hold on both sides?
Old Aug 12, 2001 | 02:06 AM
Joey9's Avatar
No, it's just a press fit splined stud. Just like a stud for a car if you've ever seen one. Later
Old Aug 12, 2001 | 04:54 PM
sparky2001's Avatar
I got it !!! I took the stock studs out of the hubs !!!
I used a tube wrench, put it in the inner side of the hub. Screw a bolt on the stud, I head it to the floor, and then hit the Tube with a hammer.
I then put the new longer studs that came with the kit.
Thanks you all !!
Now this thing is really w i d e ! ! ! !
Old Aug 13, 2001 | 12:28 AM
Zorro's Avatar
Joey,
Do you know where I could get those longer studs? If anyone sells them?
Cole Hadden
Jun 15, 2025 09:05 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
cSchwartz
Jul 9, 2015 02:40 PM
Jul 7, 2015 11:00 PM
