Adjusting the shift lever on the Wolverine
I think he is talking about the old Wolverine with the semi auto shift trans, not the new belt drive one, you dont put your boot under the shifter on the new ones, and the shifter is tied directly to the shaft coming out of the gear case, the only thing you can do is loosen the clamp bolt and take it off, then move it one or 2 splines to give you more room for the boot.
