How to loosen sprocket on a 97 Warrior
Old Sep 15, 1999 | 09:45 PM
pflueeb's Avatar
Hi people!
I have a 97 Warrior---I'm trying to get the front sprocket off in order to put a new sprocket on. I need to know---how do you loosen the bolt on the sprocket? Do you have to hold the old sprocket? When you hold the bolt the whole shaft turns. Is it clockwise or counter-clockwise?
Thanks!!!
Old Sep 15, 1999 | 11:39 PM
hot_shoe_cv's Avatar
Bob, I'm assuming that you have bent the flats of the lock washer back away from the flats on the nut. if so, the nut shouldn't be that tight unless there is corrosion.With wheels on the ground, place the machine in 1st gear, lock the parking brake,(I removed mine) or apply the foot brake & zip tie it down to the frame. This takes the strain off the tranny when you wrench the nut loose. In replacing the c/s sprocket, the specs only call for 54 ft. lbs. of torque. Don't forget to bend the flats of the washer back onto the flats of the nut. The nut has a common right hand thread, meaning that it is loosened by turning counter clockwise.
Of course, if you're going to a larger gear you'll have to loosen the adjustment on the chain in order to get it on..just a reminder
THE AZ HARD PACKER, calmiller@kachina.net
save your riding area! join the Blue Ribbon Coalition online @www.sharetrails.org
[This message has been edited by hot_shoe_cv (edited 09-15-1999).]
buddieboy
Dec 9, 2016 05:50 PM
1ArmBandit
55
Oct 14, 2015 09:03 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
merryman
Sep 19, 2015 03:15 AM
