BLASTER NEEDLE JET
Old Sep 26, 1999 | 12:45 AM
BLASTER-00's Avatar
HEY ALL
NEED A LIL HELP. I OWN A 2000 BLASTER. A FUN RIDE BUT I NEEDED A LITTLE MORE POWER, SO TODAY I UPGRADED TO A FMF FATTY PIPE + SILENCER. I ALSO PUT IN A K&N AIR FILTER AND VENTED THE BOX. IT LOOKS , SOUNDS, AND RIDES GREAT. AFTER INSTALLING MY NEW AD-ONS I WENT TO THE CARB. I WENT WITH THE #250 MAIN JET,AJUSTED THE AIR SKREW (ABOUT 1 2/3 OUT) , BUT DIDNT GET TO THE NEEDLE . I WAS WONDERING IF ANYONE WHO HAS DONE SIMILAR MODS CAN HELP. IS IT NECESSARY TO DO THE NEEDLE, AND IF SO WHAT NOCH WORKED WELL.
Old Sep 26, 1999 | 12:57 PM
hot_shoe_cv's Avatar
Blaster00,
unless you have previously moved the needle position, it is no doubt in the center slot. Just leave it there unless you have some throttle response problem between 1/4 to 3/4 throttle. That's where the needle operates. In Ma, where you are, that should be fine. Any time you rejet it's always a good idea to take a plug reading to be sure, especially on a two stroke. If you're not sure how to do that or what to look for, e-mail me & I'll run thru it with you.
THE AZ HARD PACKER, calmiller@kachina.net
save your riding area! join the Blue Ribbon Coalition online @www.sharetrails.org
P.S. B4 some one jumps down your throat, you might want to lose the caps..it looks like you're yelling.
[This message has been edited by hot_shoe_cv (edited 09-26-1999).]
Dammar
Apr 20, 2016 06:03 AM
Ahtatu
Sep 28, 2015 12:14 PM
wrencher82
Sep 24, 2015 03:39 PM
nastyblaster100
Sep 13, 2015 01:19 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
