Grizz660 trouble
I am experiencing a knocking noise when I use a rear brake.It looks like the sound is comin' from the front and feels like loose brake... I checked them /brakes/,all seem to be OK.Same sound when I decelerate.
Anyone had a same trouble??
Joe
Joe
I think it is the Ultramatic making the noise. I get the same clackety clack sound on both 2000 Kodiaks but only when stopping fast using the rear brakes. I always figured it was a normal sound like a clutch release or override or something.
I have heard the same noise from my rear brakes also. It only happens when I apply then hard at fast speeds. My solution is I don't use the rear unless I am going slow or going too fast down hill but with engine braking you usually don't need the rear brake when going down hill.
Obviously this is a n o r m a l noise. It bothers me , sounds like a loose winch hook hitting the frame/sometimes/.Yama ing's should do a better job.
Joe
Joe
joe, sounds like everyone with the griz is hearing the same sound.I also get that chatter from mine when braking on downhills.I thought it was my driveshaft and was a little worried. I guess that,s just something the griz does.
2002 griz 660 27-10-12 carlisle swamp pro
2000 yzf 426 no mods needed
I don't know anyone with a 660 that isn't hearing this so I think its normal, though it sounds like everything in hell is falling apart. I never knew if it was the transmission or the rear brake myself. Scared me a lot though early on, but now its just something to bother me I guess.
