Warrior Parking Brake Rev Limiter
Old Oct 18, 1999 | 05:24 PM
2000_Warrior_350's Avatar
I've been having engine problems while riding that I believe is being caused by the parking brake, has anyone modified their parking brake so the engine isn't limited to 2300 rpm when the brake is set?
I noticed there is a small block inside of the clutch lever housing that pushes the switch in for normal riding, and retracts when you set the parking brake releasing the switch limiting the rpm to 2300. Removing the switch doesn't work...it has to be "in" for normal operation. According to my shop manual...which only includes up to 1995 models...it shows that a green/white wire connects to ground--the only problem is that I don't know if the green/white wire is grounded for normal riding, or when the parking brake is set. If anyone has removed this lovely feature, please let know.
[This message has been edited by 2000_Warrior_350 (edited 10-18-1999).]
Old Oct 19, 1999 | 10:51 PM
EricRozum's Avatar
I've had to do this to my friends before and now i have to do it to mine (after almost flipping of a jump) if you want to know how email and i will tell you. Its not to hard
Old Oct 20, 1999 | 02:29 PM
hot_shoe_cv's Avatar
2000Warrior350,
The best modification you can do with the parking brake lever is to take it off & dump it in the trash. It's unnecessary, and that knife edged blade is an accident waiting to happen. I have the scar on my forearm to prove it. I took a particularly hard hit on a 10" deep rain rut & nearly went over the bars.Somehow my forearm hit that brake lock lever & put a nice 2" gash in it. Needless to say I went back to my truck & removed it; not my arm, the lever.BTW, that took care of the rev limiter also.
THE AZ HARD PACKER,
calmiller@kachina.net
save your riding area! join the Blue Ribbon Coalition online @www.sharetrails.org
Old Oct 25, 1999 | 03:55 PM
96bansheerider's Avatar
When you remove the stock lever all you have to do is clip the little rev limiter block off and separate the wires and tape them off so they do not touch each other or anything metal. tape them off and tuck them under the plastic.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Backwoods_badass
Aug 28, 2015 12:35 AM
Stirling
Aug 9, 2015 01:49 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
