01 Kodiac cv boot, cv joint wont come off
I am trying to replace the cv boot on my 01 kodiac, it's the front left boot next to the tire also my mechanical skills and terminolgy are very limited, ok I have taken off everything more than I should have I'm sure, I'm down to just the axel and the cv joint it's self, the axel is still attached to the front drive train or what ever it's called, my problem is I cant seem to get the cv joint off the shaft, I have cleand the grease out and I cant see a circle clip or anything that would hold it, however when I pull on it I can get it to move back and forth but I'm scared to pull to hard for fear of pulling the other end out of the drive train, can someone please help? or does anyone have a manuel they can email?
Thank you
Charles
cstotler@bluemarble.net
Thank you
Charles
You have to take the inside joint apart and slide the new boot on from the inside.Remove the inner boot and remove the large snap-ring from the inside of the joint cup.Slide the joint apart,then remove the small snap-ring from the diff end of the shaft and slide the joint off.Then you can slide off the outer boot.
You must be pretty couragous to go at that with you limited expirience and with out the manual.
If you are the one next to the wheel, that's the "outer" CV joint. In order to remove the outer, you must remove the boot on the "inner" CV joint. Then you will find a large cir-clip which, when removed, will let you pull the shaft out. On the end of the shaft you will find a small snap-ring. Remove that and you'll be able to slide the CV joint off of the shaft.
Then you can change the outer boot.
That's why if you ask for an outer cv joint boot repair kit you are given two sets of clamps. Because you must also remove the inner boot.
