Wolverine Tires
Old Sep 16, 2001 | 05:35 PM
kyleee's Avatar
I bought a used 1998 Yamaha Wolverine 4x4 and need to replace the tires. The bike has 23x10x12, but there impossible to find to replace (in canada). Thinking of going with 25x10x12 and was wondering if there are any problems with going to a larger tire. Also any opinion on the Bear Claw. Your input would be greatly appreciated.
Thanks
Old Sep 16, 2001 | 08:17 PM
500SCR's Avatar
The only problem with going to a taller tire is that you will lose some bottom end power. With a shaft drive there is no way to compensate for that other than motor work or running in a lower gear (tranny). With a chain and sprocket, you could just change the sprockets. Be carefull how tall you go with.
Scott
Old Sep 17, 2001 | 09:12 AM
Camo-man's Avatar
I have 26x12x12's on mine. I did lose some bottom end,
I have read that if you go large tires on a wolverine 25's are the best size. I drilled my clutch so that the clutches enguage faster...
I will be getting a jet kit also to help out......
Old Sep 19, 2001 | 01:07 AM
ridnwarrior's Avatar
Go to troy-racing.com. They have a microfiche section you can use. Look on that for your year and make of quad. You can order the stock tires from them for the Wolvy.
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
highwayman
Sep 19, 2015 12:59 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
