Lagging acceleration and response on my blaster!!! please help
Old Sep 19, 2001 | 02:45 PM
Quadster17's Avatar
I have a 97' blaster that isn't getting the throttle response like it ought to. I cleaned the air filter and oiled it. I haven't messed with the air/fuel mixture screw. Anyways, how many times is it suppose to be unscrewed? 2and 3/4 turns out? anyways, it's not popping wheelies as good as it usually does in 2nd gear and isn't accelerating to it's max potential. I'ts still accelerating ok, but not like it usually does. please, need help. reply back.
Old Sep 19, 2001 | 03:37 PM
timewass's Avatar
Check the tips of your reeds for cracks or worn spots. Also check/change your plug and make sure you are running fresh gas.
Old Sep 19, 2001 | 04:05 PM
ridnwarrior's Avatar
Have you done a compression test? Might be time for new rings.
Old Sep 25, 2001 | 04:21 PM
BLASTERDEVIL1's Avatar
your a-f should set at 1 1/2 back.
Old Oct 3, 2001 | 09:23 PM
98blasterFlash's Avatar
Getting a set of reeds will make it have better throttle response
Customer Service #1
May 15, 2020 08:46 AM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
alzgarvin
Sep 11, 2015 08:53 AM
