Is Jet Kit Worth buying 4 Grizzly?
Old Nov 8, 1999 | 07:25 PM
Jamie's Avatar
Does anyone have or know anything about a Jet Kit?Is the power gain worth the money and can you install it yourself?
Old Nov 11, 1999 | 11:19 PM
azrob's Avatar
The Grizzly has a 40mm CV carb that's not only hard to get at, but would also be difficult to work on. A K&N filter would probably give about the same gain, as well as disconnecting the speed sensor ( directions are in another post on this group).
Old Nov 12, 1999 | 10:10 AM
YamaHonda's Avatar
azrob,
What does disconnecting the speed sensor do for you? This is the first I have heard of this, so I'm just curious. Any info would be appreciated. Thanks!
Old Nov 12, 1999 | 10:24 AM
YamaHonda's Avatar
Jamie,
I don't know that a jet-kit would buy you much without installing a new exhaust system. I have the K&N Filter w/Outerwear on my Grizzly and have not noticed any substantial gains (if any). When I first put the K&N on, I went up one size on my main jet and the bike ran too rich (I didn't change the needle or clip settings). Like azrob said the carb is not easy to get to on the Grizzly. I can't count how many times I have had the front plastic, rack, and gas tank off of this machine. I almost have it down to an art.
The K&N doesn't fit that well in the airbox, so I would recommend staying with the stock setup. Apparently the K&N did not provide much more air flow than the stocker or the stock jetting would have been to lean, but this was not the case. The Grizzly (atleast mine), runs on the rich side to begin with.
A buddy of mine has a Grizzly with the FMF Megamax, K&N, and a jet-kit and he has found substantial gains with this setup. I've seen him pull wheelies on dry ground with 27x12" Vampires all the way around. I can pull the wheelies, but I need a couple feet of water to get the front end to float up!
greg74
Sep 10, 2019 03:03 PM
Jul 28, 2015 12:12 PM
RticKwad
Jul 21, 2015 03:00 PM
MATT BOOTH
Technical and How-To Articles
Jul 20, 2015 07:38 PM
toonces
Jul 11, 2015 12:01 PM
