What are the best nerf bars for a Warrior
as far as i know the warrior nerfs go on the same as blaster nerfs they bolt onto the pegs and bend slightly to fit snuggly with your peg on the blaster the front mounting bolt has to be removed and longer one that came with the kit had to be installed to attach the nerfs at the front.
i got ac racing nerfs i think they are nice and light and strong
Since I've not used all the different brands, I can only tell you about the Graydon's, which is what I use. The rear bar of the nerf bolts to the foot peg. On the Warrior, it requires two holes to be drilled in each peg. the front bar goes across the top of the frame & is clamped to the frame on each side. They are quite strong in spite of their light weight (alloy) & have taken some fairly hard hits with no damage other than scratches.
THE AZ HARD PACKER, calmiller@kachina.net
save the public land FOR you, not FROM you..join the Blue Ribbon Coalition online @ www.sharetrails.org
One thing you might consider is whether or not the webbing/stapping is removable or not. I do know that it is removeable (replaceable) on the Graydon type. The webbing is looped in at various points and
can be removed or replaced if you damage it or want to polish the nerfs.
Rude Dog
[This message has been edited by Rudedog (edited 11-12-1999).]
Rude Dog
badgerboy1
09-26-2017 06:11 PM
