Yamaha Terrapro?
Old Nov 19, 1999 | 10:28 PM
BushHog's Avatar
I heard about a Yamaha that had a pto shaft out the rear. Anybody seen/used one of these quads? I might be interested in trying one.
BushHog
'99 Sportsman 335
Old Nov 19, 1999 | 10:57 PM
mudman's Avatar
ah the old terrapro`s. they dont make them any more. if you wanna compare them they were like the polaris 6x6 quads except that they had a flat bed on the back instaed of the styled one that is on the polaris`. i dont know if they had a pto rear shaft drive on the back though.
Old Nov 20, 1999 | 01:31 AM
BC_YFS200's Avatar
Had one for a few years.
What do you want to know?
YFS200
Old Nov 22, 1999 | 11:41 PM
BushHog's Avatar
Was it good for anything? Was it a 6x6 like mudman said? 4 wheel drive?
BushHog
Old Nov 28, 1999 | 03:27 AM
BC_YFS200's Avatar
Nope. It only had 4 wheels. Not even 4 wheel drive, but most people don't take a mower in places that require 4-wheel drive. And at the time, having 4-wheel drive would kill the great turning ratios. I don't recall exactly, but I think it had some type of posi-track diff in the rear. Worked well.
Other neat things. A manual clutch. High low range. And cruise control. So you could keep the engine at one RPM without using the thumb throttle.
No flat bed or anything. Just a normal quad with wide rear tires.
I had the mower and rotortiller attachment. The mower was handy and worked quite well. Having control of it on the quad was a plus.
The tiller was OK at best. Getting the 3 point hitch aligned correctly was horrible. took 30 minutes to hook up if you where good at it. And the tiller used a satellite arm to lift up and down. It could not handle the stress and soon broke.
I LOVE the PTO idea. It has so much potential. A water pump for a spray rig. Or a high flow water pump for when you need to empty out a pond. A 5kw generator/welder would be killer. Hydraulic pump would be nice.
I wish Honda would make a quad with a PTO. Some of the areas I need to get back to, was an ATV only with no trailer. Having a built on welder to go fix busted equipment is well worth a higher price.
Honda? Hello? Market here!!
YFS200
buddieboy
Dec 9, 2016 05:50 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
jbrewster94
Sep 23, 2015 04:16 PM
Sep 23, 2015 06:23 AM
