LOOOK HERE!!!
Old Dec 10, 1999 | 11:40 PM
clindst's Avatar
What quad is the best rec/utility quad, i need a big bore either a 400 or a 500 4 stroke and i dont like that 3 WD Limited slip front diferential
Help
Old Dec 11, 1999 | 12:14 AM
bignasty's Avatar
I would definately consider the 500 Magnum a good rec/utility quad. I'm not saying the best because I'm not sure what type of rec riding you do. If it's basically trail riding and things like that, it would to okay. It is well suited for my needs over flat terrain. But if you ride over bumpy terrain and rocky obstacles, the 500 Sportsman would be a better bet. It has IRS and alot of ground clearance. Both have True 4 Wheel Drive, not limited slip. And the Magnum makes a good utility quad also. Very powerful and dependable engine. I assume it's the same with the Sportsman because it's basically the same engine.
Old Dec 11, 1999 | 12:19 AM
clindst's Avatar
thats what i thought too i like the magnum if i get it it will have EBS and it has the smae ground Clearance as the sp500 and the hitch on the bak doesnt slower because of the IRS
Old Dec 11, 1999 | 12:43 AM
BONER's Avatar
Clindst,
Where do you live?
Old Dec 11, 1999 | 12:48 AM
clindst's Avatar
bONER, I LIVE IN SOUTH CALIFORNIA BUT I HAVE A SUMMER HOUSE IN MINNESOTA AND THAT IS WHERE I RIDE A LITTLE TOWN CALLED MORA MINNESOTA A LOT OF RIVERS AND FUN
cHRIS
Old Dec 11, 1999 | 12:56 AM
BONER's Avatar
I wouldn't requimend the EBS in Ca. because down here in Louisiana the humidity and the heat combined with the extra heat from the EBS cause alot of melted belts and cover dwn here. If you are in the mountains then it is a must. Plus in the Mountains it is cooler so it is better. But I dought you will have a problem with it in MINNESOTA.
Old Dec 11, 1999 | 02:05 PM
clindst's Avatar
Boner i only ride in minnesota
Old Dec 11, 1999 | 10:34 PM
BONER's Avatar
Good, because I would hate for you to have trouble with your quad. What tpe of riding will you do?
Old Dec 11, 1999 | 11:55 PM
clindst's Avatar
I do all types of riding, such as trail riding mud riding pulling A LOT (Take my word) Deep water crossings and so on, i have a question about teh Polaris belt when i am pulling a 6000 lbs boat and i am putting a lot of strain on the Atv and barely geting the tires to break loose is al that stress gonig onto the belt? if it is ill go through a lot of belts what is the best Atv for me?
i was looking at the Magnum 500 but only concern to me is the belt
Chris
Old Dec 12, 1999 | 12:07 AM
Timberwolf82's Avatar
I would REALLY consider the NEW Big Bear 400 model for 2000! It lookd like a great atv to me! I own a 99 350 Big Bear 4x4 and am VERY VERY PLEASED WITH IT!
