Dyno-Jet/K and N kit and the Raptor
I have the Dynojet kit that came with new springs, needles, and plenty of jets all the way up to 150. The needles are in the recommended clip position and I am running 148/150 jets without most of the airbox lid and a White Brothers PowerFilter. I have the GYT-R carbon fiber tip and fairly stock headpipe. I am <3000 feet of elevation. Plug color is brownish, no hesitations anywhere.
I think the needles are key to keeping the engine performing perfectly across the entire RPM range. Not sure you can get it tuned quite as well just changing stock jets.
/NotuRaptor
/NotuRaptor
I just did the dynojet kit, the k&n filter and the big gun exhaust (complete). I am very happy. It runs great. I think the jetting is pretty darn close. I will be pulling the plug in the next couple days to check it out and see what I am doing. I believe I am jetted a little on the rich side. I used their reccomendation for the 3000-6000 ft altitude and I live at 6200 ft. I did this because I frequently ride here, but also ride alot in the 4000 ft range. I will know more when I pull the plug.
I am currently using the entire airbox lid. I did cut it, but I still have both peices in their place. I am going to be doing some experimenting and see where it runs the best.
I did have one problem, when I did the kit. I got it all done and then was running it in neutral and it was sputtering and popping and all kind of noises. I was not sure what was wrong. I called the dynojet number and he told me a couple of things, but said it sounded like the slides where not working right.
I pulled it apart and he was right on. I did not get the slides seated and they were not working right. I fixed it and it runs great.
I beleive I am at 144/146 jets.
Hope it helps
Paul
Hope it helps
Paul
the dynojet kit is great, I ride anywhere from 4000->8000" and rejet all the time for the conditions I will be in that day, stock directions will get you in the ballpark then it just depends on altitude, pipes, airfilter and airbox. first time jetting is a pain, but no big deal. do the kit
Alex Rodak
09-13-2015 12:30 AM
Alex Rodak
09-12-2015 09:39 AM
Alex Rodak
09-11-2015 11:42 PM
