warrior the biggest piece of dung!!!!!!!!!!!!!
Old Oct 14, 2001 | 08:41 PM
Tooey's Avatar
WEll you know when u turn the key on it click's in right, then u hit the start and the starter relay kicks in. MY battery is brand new. Could it be my starter switch?? i have no clue me and my wiring don't get along too well...
Old Oct 14, 2001 | 10:45 PM
yamahagye's Avatar
You have one little problem and the warrior is the biggest piece of "dung"? If that is true, all quads are "dung" because every quad has some little problems. some 400ex's have problems. some raptors have problems. some ds650's have problems. so do all of these quads suck? nope.
Old Oct 15, 2001 | 12:35 AM
KENTUCKYHILLBILLY's Avatar
not real sure wat you are trying to say with the "clicks" but it sounds like a relay or a ground. One of the relays has a red with a white stripe wire and a blue with a white stripe wire. cut theose behind the relay and wire them together.
Old Oct 15, 2001 | 07:59 PM
Tooey's Avatar
okay thanks guy's for the info. Yeah i know every bike got a little problem but this hog i got from this guy's is crappy, but it is the fastest warrior i ever rode. I am eventally goin to get something new. dunno yet what it is gonna be...
Old Oct 15, 2001 | 08:36 PM
mdegain's Avatar
You might also want to check that fuse underneath the relays to make sure it isnt blown. If it is, replace it and check all of your electrical connections for corrosion.
Oct 10, 2015 10:20 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
mbriggs
Sep 13, 2015 10:47 AM
toonces
Sep 5, 2015 01:14 PM
