Slight Hesitation when letting off the throttle on 'da blue beast
airraptor i cant help but to disagree with you about the stroker kit. A stroked motor slows the piston down at tdc and can if the crank is strong enough, the mains and the angle of the piston is not to great make a motor more reliable by causing less strain due to the longer stroke. If you think about it its impossible for a motor with more travel between the bottom to the top to increase speed, it takes more time to go the bigger difference. I may be wrong iam not totally familiar with raptor engine kits. I may be and propably are wrong please dont be affended iam just sort of curious how a stroker kit is causing more speed on the rotating assembly. Is it just that particular kit and its other mods? Like cam and ignition changes or do they "egg shape" the crank? Maybe it has a lightened flywheel. I dunno.
#16
