What tool do you Raptor and Banshee guys use to sync the carbs ?
Old Oct 20, 2001 | 08:09 PM
jefffoxsr's Avatar
I need a tool to sync my carbs on the 650. What tool should I use and where can I buy it?
Thanks.
Old Oct 20, 2001 | 09:53 PM
whipit's Avatar
I havegot aMotion Pro carb sync tool thatiuseon my streetbikes but i have never done anyquads with it.did an Indy 500 withit last winter. it worked great. I dont know that the dual carbs on the raptor will need to be synced since it is only a single cyl. motor.
Old Oct 20, 2001 | 11:19 PM
EDD's Avatar
EDD
the fastest spur of the minute check is to put a spacer inside each carb and close the slide till each one just touches it.a carb synch tool is the best way but i dont belive the raptor needs to be synched due to the fact it has vacume activated slides,if the carbs are not opening at an evan pace id check for a air leak in one of youre carb diaphrams.if thats not it the jetting in one carb mght be off due to a clog in one jet.id recomend to every one to put in a in line fuel filter on there raptor.7000. you would think they could give us a 1.00 filter.hope some of this helps.
Old Oct 20, 2001 | 11:22 PM
EDD's Avatar
EDD
im sorry i didnt notice we were talking kawasaki,ive got raptor on the brain..if youre carbs are not vacume activated just disreguard that part.the rest should still be true..i belive motion pro makes a carb synch tool.
Old Oct 21, 2001 | 12:45 AM
jefffoxsr's Avatar
Thanks guys
armpump450r
Technical and How-To Articles
Apr 1, 2017 06:11 AM
Timjunior
Ask the Editor
May 28, 2015 01:09 PM
B4NSH333
May 26, 2015 06:55 AM
OLDSTER
Jan 9, 2001 10:13 PM
RaptorGuy01
Oct 31, 2000 04:23 AM
