Big Wheel
Old Oct 24, 2001 | 09:35 AM
rancheres's Avatar
Anyone ever had any experience with one of these? For those that aren't familar, it's a motorcycle with ATV tires, powered by a one cylinder 350cc engine. They were just made (I think) for a few years in the mid 80's. I've got one that according to other souces has a carb problem, I think one of the jets always gets clogged. Anybody have a solution to the problem, as the stock carbs have some short comings?
Thanks for you help.
Old Oct 24, 2001 | 10:02 AM
Zorro's Avatar
What's the problem?
Old Oct 24, 2001 | 11:46 AM
rancheres's Avatar
Idles at a very high rpm and gas leaks from the bottom of the carb, at a fairly quick rate. According to others if you don't shut the gas off when in use the bottom jet gets clogged, does that make any sense?
Old Oct 24, 2001 | 11:47 AM
rancheres's Avatar
sorry for the typo, should have written if you don't shut the gas off while quad is shut off then you have problems.
I've just heard that Yamaha had a lot of carb problems with these models, don't know what the solution should be.
Old Oct 24, 2001 | 11:51 AM
Zorro's Avatar
Well, maybe the gas supposed to go in the engine overflows (instead of going in), causing a lean condition -> high idle.
The safest thing to do is remove the carb, clean it...and see if anything is wrong. From there, you'll have a new starting point (and I guess it'll be enough to have it running again)
Old Oct 24, 2001 | 11:52 AM
Zorro's Avatar
You might also want to check how good is the air filter, and add a fuel filter. Especially if the gas tank is steel.
badgerboy1
Sep 26, 2017 06:11 PM
Oct 10, 2015 10:20 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
tysonbully
Sep 28, 2015 02:30 AM
r1pilot83
Sep 27, 2015 07:38 PM
