Brand new 02 Banshee break in procedure???
Old Oct 31, 2001 | 11:01 PM
KEVPOPPAPUMP's Avatar
The dealer tells me to ride for twenty minutes conservatively then let the quad sit for twenty. Is this true, thats it? I just want the best for my Banshee and I want it to have a long troublefree life.
Old Oct 31, 2001 | 11:11 PM
mongo350's Avatar
Make sure you get rid of the stock air filter ASAP,It is a problem just waiting to happen.
This will help make your motor last.
As for the break in, When I broke mine in, I rode for a half hour let it cool down and then I would ride for a half hour or so, I did this 3 or 4 times then changed the oil and then started riding it normal after that and not had any problems with the motor (I've had it since 1999).
Old Oct 31, 2001 | 11:22 PM
I would like to get a pro-flo intake but I'm hesitating doing so because of the rejetting thing. I don't know anything about 2 strokes let alone carburators. I have to really dig into the service manual I ordered before I feel comfortable making any mods.
Old Oct 31, 2001 | 11:40 PM
mongo350's Avatar
You could go with the pro-desighn foam filter this should not effect your jetting, But (there is always a but)in the long run you are going end up wanting the K/N set up and you will have to re-jet for that.
Which ever one you go with it will be a great improvment over the stock set up, and will save you the cost of a rebuild.
Old Oct 31, 2001 | 11:43 PM
Raptoryfn660r's Avatar
RIP Dear Friend
I thought the 02 Banshees had the updated or new for 02 air filter assembly. Chet
Old Nov 1, 2001 | 12:54 AM
KNOWSALOT's Avatar
The Facility
The advise that your dealer told you is the best method. I wouldn't jet,pipe,or do ANYTHING to your bike until you run at least 4 or 5 tanks of gas through it. Sometimes,but not always, two strokes will have to be "re-tuned" after break in. If go and add alot of stuff to it it makes it harder to figure out the problem. We see this quite often when one buys a Banshee, Blaster, or a dirtbike and wants us to put a lot of performance parts on it. Alot of people don't realize the difference but it IS there. Hope this helps.
ltzbrad
Sep 25, 2015 05:52 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
black798
Sep 9, 2015 07:42 AM
Elkaholic
Sep 6, 2015 02:44 PM
