'95 Blaster
Old Jan 18, 2000 | 09:39 AM
MDP49's Avatar
What would cause gas to leak from the carb vent tube on a '95 Blaster?
Old Jan 18, 2000 | 11:09 AM
sAyIt_fmf's Avatar
Stuck floats in the bowl would be the best bet I think.....Take the bowl off the carb and check it out.
good luck
Old Jan 18, 2000 | 04:41 PM
MDP49's Avatar
Thanks...I'll check it.
Old Jan 18, 2000 | 06:23 PM
blstrpro's Avatar
The same thing happend on my yz490 when I turned the gas on. I took the bowl off and took the flots off and put them back on and it quit.
Old Jan 19, 2000 | 01:22 AM
Blast_Happy's Avatar
There is a valve and seat that regulates gas into the float bowl. Sometimes the float is working fine but the seat has some dirt on it not allowing it to seal off and the gas keeps leaking into the bowl and overflowing. Take the bowl off and remove the valve and seat and re-install.
Old Jan 21, 2000 | 11:56 AM
MDP49's Avatar
My brother took off the carb and made sure the float wasn't stuck. He put it back on and it still leaked out the tube. Is there an o-ring or seal around the needle valve that could need replacing? I'll know more this weekend when I get to look at it personally. So far I've only talking to him on the phone. Thanks.
Old Jan 21, 2000 | 12:27 PM
As I said in my other post there is a valve that can be replaced under the float. After the float is pulled there is a little hook that attaches to the bottom of the float. Remove the screw and retaining fork and pull the valve. The whole valve can be replaced. I'm a little suspicious on a '95 that the valve is bad though. It's possible that the float is not positioned properly.
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
