HELP !!!! Trail Tech Speedo
Old Nov 7, 2001 | 06:36 PM
sneves's Avatar
I bought it used with no directions. I need to know the # to put in the
computer to calibrate to my tires. Im running 23 x 7 X 10 XLC holeshots with douglas rims .
Old Nov 7, 2001 | 07:53 PM
EDD's Avatar
EDD
you might want to do a search on the web and see if they have a page that tells you,,chances are if they dont some one else does.just look a little it some times pays off.
edd
Old Nov 7, 2001 | 08:12 PM
95Warrior's Avatar
Quoting: "On flat surface, mark the sidewall and the ground with a marking pen. Roll the wheel until the mark on the tire completes one revolution and is back on the ground. Mark the ground at this location. Measure the distance between the marks on the ground and convert the measurement to mm. Use this number for your wheel size. For accuracy, the riders weight should be on the bike when making this measurement." For reference, on my Raptor with stock tires and rims the measurement was 1585 mm.
Old Nov 7, 2001 | 08:16 PM
Pull's Avatar
I have the same computer speedo on my raptor ( Panoram ) by trail tech.
You can compute the # by multiblying your wheel diameter by 3.14 X 25.4mm/in.= total millimeters.
example 23" wheel x 3.14 x 25.4 = 1834mm Only good if your tires are rock hard.
To get a more accurate number, measure the distance your wheel makes in one complete revolution by placing a tape measure along side the machine. Then multibly the distance in inches by 25.4 mm/inch. This allows for the tire flex.
Old Nov 7, 2001 | 08:34 PM
URPREY's Avatar
Trailtech homepage
Old Nov 8, 2001 | 03:02 AM
Popo35's Avatar
Raptorbrad posted a good idea on bluetrxx. About making the speedo displaying faster.
I did this a works great.
On to making it faster. Get a second magnet, put it at 180 degrees offset from the first one. Divide your MM setting by 2.. and it should be alot faster. The slowness comes from only updating every 2 revolutions of the tire. Well at low speeds thats alot of time. With 2 magnets on the wheel it will update every revolution. Dividing your tire size by 2 offsets having the second magnet.
Old Nov 8, 2001 | 09:44 AM
BansheeBrad's Avatar
RaptorBrad.. BansheeBrad... that's me.. lol.. 2 different names 2 different boards...
Yes the above trick works.. 2 magnets will make it alot better
also On my 23 inch tires, I set it to 1755 (with 1 magnet, I use 877 with 2) on 23 inch Bandits and it matches my GPS perfectly.
Brad
Old Nov 8, 2001 | 04:42 PM
Thor2's Avatar
Hey guys,
While your two magnet idea helps the speed update, it is only half of the solution. The second half of the solution is in the new TrailTech computer (not shipping for another week). The computer updates based on two variables:
Number of triggers per unit time.
Units of time.
The current computer will only update the display at a maximum rate of 1 times per second. The new computer will update the display at a rate of two times per seconds.
If you call and ask for a software upgrade, they will provide one for $20.
Old Nov 8, 2001 | 05:24 PM
URPREY's Avatar
That's great, but I just bought mine a few weeks ago. I'd hate to think I had to pay another $20 to get a "newer, better model" [img]i/expressions/face-icon-small-sad.gif[/img]
Old Nov 8, 2001 | 09:01 PM
95Warrior's Avatar
What is the procedure for the "software upgrade"?
