NEED INPUT! Raptor rear axle bearings.
I have replaced mine I used o.e.m.bearing and seals
because I have a warranty my dealer just gets me
the parts and I do the work (less down time)
but any good bearing and seals aftermarket will
work when you have that apart you might want to
grease your swingarm bearings also while she's
apart the axle bearings arn't hard to do just
bang then out with a punch sand your seal area
on the hubs and grease the seal lips and use the
old bearing and a block of wood and bang them in
or if your a machinist like me you make a install
tool also put the carrier in the oven at 400 and
heat it up a while it will ecspand making it easy
and put a little grease inside the carrier so it
slides in easy hope this is of help
