Warrior Rev Limiter
Old Jan 23, 2000 | 11:36 PM
NoFear29's Avatar
Do the '99 Warriors have rev limiters? I know there is an adjustable screw on the throttle to keep inexperienced riders from going to fast, but my screw is backed all the way out. It seems that when i get to a certain or rpm in 6th gear it sounds like I slipped out of gear. When I let off the throttle a bit it engages again. Is this normal? Is there a way to fix it?
NoFear29
'99 Warrior
Old Jan 24, 2000 | 12:56 PM
Mr45auto's Avatar
Make sure you are fully engaged in gear. Keep upward pressure on your shift lever as you release the clutch, you should feel it drop the rest of the way in and the problem disappear. As far as a rev limiter I believe that it's mechanical and not electrical. Your valve springs float long before any rev box kicks in. If you want more RPM's it's a cam/valve spring swap ya need.
Old Jan 25, 2000 | 12:03 AM
NoFear29's Avatar
The gear us already engaged.. this happens when I am at or near the top end of 6th Gear.. I dont know if i have just reached my bikes top end or there is a mechanical problem.
NoFear29
'99 Warrior
Old Jan 25, 2000 | 12:12 AM
Banshee_16's Avatar
Does it do that in every gear at high RPM? Never seen anything like that happen on a Warrior. You may have a broken valve spring, and when you get to a high rpm your valves start hanging. But I would get some more advice, before you tear into the top end.
Old Jan 25, 2000 | 09:19 AM
sik_banshee's Avatar
Sounds like the clutch is slipping.
If it was the rev limiter it would be more apparent in the lower gears.
Old Jan 25, 2000 | 11:28 AM
NoFear29's Avatar
This only happens in 6th gear when I am completely wide open for a while... I think I am right about at the top end when this happens.. And it does sound like it is slipping..
Old Jan 25, 2000 | 12:06 PM
2000_Warrior_350's Avatar
Sounds like what my Warrior was doing when I was re-jetting it a few weeks ago after a few mods. When the main is too fat it'll start blubbering (similar to what a rev limiter might feel like) right at WOT--which indicates you're too rich on the main--and if it's really rich it'll definitely die until you let up on the throttle. I know you said this only happens in 6th, and that jetting relates to throttle position and not to what gear you're in, but when I was too fat on the main it was more apparent in 6th than any other gear. Don't ask me why, but maybe it has to do with the load on the engine in 6th versus any other gear.
Anyway, try this--pull the carb and see what you have for a main jet...stock is 145. Depending on your elevation and whether or not your ride has had any mods (knowing this might help diagnose your problem), if the main is bigger than the stock size, drop one size and see how it reacts at WOT. If the problem clears up or else less noticeable, then you know it's a jetting problem and can work from there.
[This message has been edited by 2000_Warrior_350 (edited 01-25-2000).]
DGNAZ
ATV Expeditions
Jun 22, 2017 04:20 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
