banshee stator ???
Old Nov 18, 2001 | 01:29 AM
mster's Avatar
how do i get to the stator to clean it up. ive been told by a few people that this is why it wont start cold. ive removed the cover and the nut but i cant get the flywheel off. do i need a special tool??
thanks!
Old Nov 18, 2001 | 01:42 AM
raptor720's Avatar
You need a special tool or you will cause major damage. Usually cold start problems are a result of worn piston rings, the choke tube being loose between the two carbs, bad spark plugs, bad gas or?
Old Nov 18, 2001 | 02:33 AM
Elrancho's Avatar
Before working on the stator, it's more likely that your cold start tune is off, or you have low compression. Easiest-Check the spark with a plug gapped slightly wide, it should still have a strong spark in a wide plug, ( inside the motor smaller gaps are nessessary.) Weak or no spark, diagnose, fix-maybe it is the stator. Next harder, check compression, use a guage to make sure it's in spec for both cylynders, if not, it's gonna need a top end sooner or later anyhow. Third, you have spark and compression, it can ONLY be the gas and/or mixture. Find the error in tuning in one or both carbs.
Old Nov 18, 2001 | 12:32 PM
mster's Avatar
can you tell me what the compression should be??
thanks for all the great info
ultangler
Nov 30, 2024 01:35 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
kbazzy
Sep 26, 2015 11:26 AM
johnny1982
Sep 13, 2015 07:41 PM
zPuls3
1) Engine problems..
Sep 12, 2015 08:54 AM
