blaster burns gearlube
Old Jan 28, 2000 | 02:15 PM
blaster89's Avatar
I have an 1989 yamaha blaster that I burned a hole in the piston on. I rebuilt the motor (new piston,rings, bored, cleaned and chamfered ports). After, I reassembled the motor it ran good for about a block, and then started to burn gearlube terribly and run just as bad. I have since split the case and cleaned and examined for cracks warpage etc. I didn't find anything wrong with the case halves, so I resealed them using loctite 518 gasket elimnator, which is made for aluminum. I also replace the oil seal and the pto side. But, it stills burns gearlube. I am so confident it is burning gearlube I disconnected the oil injection line and it still smokes terrible. Any help on this problem will be greatly appreciated.
Old Jan 28, 2000 | 06:26 PM
sombre's Avatar
Check the crank seals again.Either they are not in properly or the bearings are bad and causing the seals to go bad
'98 banshee
Old Jan 29, 2000 | 04:35 AM
BC_YFS200's Avatar
Do an pressure test, (not compression) that will tell you if the seals are all in good working order.
YFS200
Old Jan 31, 2000 | 10:51 AM
blaster89's Avatar
How do you perform a pressure check. I asked my local dealer to do this and they said that they didn't have the tools to do a pressure check.
Ahtatu
Sep 28, 2015 12:14 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
bvolks
Sep 13, 2015 12:57 PM
