question for 2000_warrior_350
Old Jan 30, 2000 | 11:49 AM
maddog357's Avatar
I read in another question where you said you did some mods and haad to rejet. I put a white bros e series on my warrior and cant get it to run good at low end and top end together. I rejetted according to instructions but it sounds like it starts to miss when i get to upper rpm in any gear. It pulls great out of the hole then sound like sh##. Here is what all i have done. top end rebuild 1st over with weisco piston. the exaust. rear sprocket and front sprocket add a tooth. It looks like it is rich from spark plug inspection......I took the air box intake off.... should I put some holes in the lid to try to lean it out? It will also Pop when i let off the throutle alothough i can solve thiss by the mixture screw(richer) it will not solve my blubber problem. I did all of this to gain power and am VERY dissapointed with the results!!!!!!
ps the main jet is the largest in the dyno jet kit i purchased. Any set up help would be great. I am frustrated and have been riding it the way it is..
thanks
maddog
PSS I ALSO HAVE A K&N FILTER ON IT.
[This message has been edited by MADDOG357 (edited 01-30-2000).]
Old Jan 30, 2000 | 04:50 PM
2000_Warrior_350's Avatar
Well, I tried to post an answer but my 'puter locks up when I try to submit it, so I'll have to send you an email
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
