Blaster throttle?
Old Nov 27, 2001 | 06:16 PM
hondaquadrider's Avatar
I got a 2000 Blaster and when i take off down the road, it takes off wide open on its own, what could be the cause of this, its pretty fun to ride when it does that......lol but i gotta get it fixed. thanx for the info.
Old Nov 27, 2001 | 11:52 PM
banshee1000's Avatar
Hi,
You may want to check the cable, see if it's getting stuck, then you can check your carb and make sure the butterflies are not sticking, one other thing is that maybe your engine is not getting enough oil, some engines will take off like that when they lean out. My thoughts, hope this helps
Old Dec 30, 2001 | 07:34 AM
my94blaster's Avatar
HEy, do you go to the sand dunes alot? cause on my blaster, after a while, sand go built up in the little box tthat the trotle cable runs to by the carb, adn since the throtle button is spring loaded it comes back no matter what. but when the dirt gets built up inside of the box, it makes the cable stick and that can be soemthing that is doin it
Old Dec 31, 2001 | 10:47 AM
tom18801's Avatar
it could be sucking air form between the carbuerator and the engine that would cause it to lean out or it could need crank seals does it stall after it screams
Old Dec 31, 2001 | 02:40 PM
spooge's Avatar
I also own a y2k blaster that does that but only when its cold out.Two different things have been the culprit;One water and mud got into the cable and froze the cure thaw it out and spray wd40 into the cable,two the thumb throttle got water into the plastic bushing inside the housing and froze the cure take it apart and clean it with wd40.You may also have a broken or worn out return spring inside the thumb throttle housing that can not be fixed with wd40 so you'll need to replace the spring.
2quiker
Mar 22, 2022 08:36 PM
MeadowlarkFarm
Nov 27, 2019 08:40 PM
nastyblaster100
Sep 13, 2015 01:19 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
