looking for mounting bracket for key switch and lights when replaceing steering stem..
Old Jan 8, 2002 | 11:05 AM
herbdon's Avatar
i am replacing my stock raptor steering stem and handle bars with a lonestar +1 anti-vibe chrome stem and tag handle bars. What i need is information about a manufacturer of a mounting bracket for the key switch and reverse/neutral/overheating that the stock setup has...I want the key and lights to remain on the bog bone/steering stem. I am aware of the light bracket that alba makes...i am also aware of the key switch bracket that www.x-racing.com has, but it is only for the key...it doesnt provide any mounting for the reverse/neutral/overheating lights....please anyone with any other manufacturer information, please drop a reply here or email me....herbdonscala@hotmail.com
herbdon out....
Old Jan 8, 2002 | 12:03 PM
RaptorRidingOut's Avatar
I replaced my steering stem also lonestar +1...depending on your bars u might hace to replace your brake lines and throttle cable....Back to your problem I dont know of any brackets...I mounted my ignition on the left side of the cover to the radiator. The lights I mounted on the right....Go here and check the third pic.....double click it.
Old Jan 8, 2002 | 12:06 PM
FISHER1648's Avatar
Trail tech - at rockymountainatv.com has a nice looking one as you described.
http://www.rockymountainatv.com/home.asp?sid=0000832916
Old Jan 8, 2002 | 12:24 PM
VMAX12's Avatar
i have the ALLOY SPECIALTIES billet bar clamp its the best i ve seen. it has a spot for the key and the lights. its polished and has the name raptor etched into it.
they have a web site alloyspecialties.com. it comes with stainless allen bolts
better looking than the others!!!!!!!!!!!!!!!
01BLU660R
Old Jan 8, 2002 | 05:48 PM
01Raptor660R's Avatar
Your in luck!
U.M.I. makes one I don't recall the price maybe around $50 made of billet aluminum.
Trail Tech makes the other. Ebay had it for like $20-$25, retails for like $39.95, this is also made of billet aluminum. (www.trailtech.net)
The reason I know is because I have been looking for these because I want to change bars to the Renthal and wanted a cleaner look than the plastic mount.
The Trail tech one says all the wiring tucks up neatly under it.
Both have the holes for all the lights, the key switch and the vent hose from the tank.
Old Jan 8, 2002 | 05:53 PM
AZDUNNER's Avatar
Try UMI.
I'm not sure it will fit your new stem but they have several to choose from that have the mounting holes your looking for. You might also ask the manufacturer of your new stem.
http://www.umiracing.com/
Old Jan 8, 2002 | 05:58 PM
BlueLeader's Avatar
I have one from Trail Tech and I like it. also disconnected my stock lights and have two 50W handlebar mounted lights.
jayking232003
Dec 4, 2019 09:38 AM
3quadbob
Sep 18, 2016 09:46 PM
NewHillBilly
Jun 14, 2015 11:42 AM
Dpearson03
Utility ATVs
May 29, 2015 04:51 AM
trx430ex
Oct 18, 2000 01:11 PM
