bigger tires affect the toe in specs.
Old Jan 8, 2002 | 08:16 PM
johnpaul's Avatar
just installed a set of 27 inch tires on the 660 grizz. would anybody know if that would effect a change in the factory settings.
Old Jan 11, 2002 | 01:47 AM
ridnwarrior's Avatar
Sure, but it can't be that much. What is the stock tire size and what is the toe in setting?
Old Jan 11, 2002 | 09:54 AM
johnpaul's Avatar
went from 25/8/12, 25/10/12 to 27/9/12 and 27/12/12. the books calls for 0 to 13mm toe in. ran string last night and i have 0 toe in. wheels looked pretty straight. try them and see how it handles.
Old Jan 11, 2002 | 01:14 PM
You always need to have some toe in on any vehicle. Set yours for an 1/8" to 1/4" toe in.
Old Jan 11, 2002 | 05:23 PM
johnpaul's Avatar
whats the best way to check the toe in. can i just mark the sides of the front wheels at 3 and 9 o clock. an take my 1st measurement and the roll then quad forward.
Old Jan 12, 2002 | 12:56 AM
I set my quad on a nice flat surface. Put the handlebars so they look straight. Then I roll it forward so the tire makes at least one full revolution. You're supposed to measure from the center of one tire to the center of the other tire. Do not roll the quad to take another measurement. You need to take both the front and rear measurements without moving the quad. You mentioned 3 o'clock and 9 o'clock. Well because your frame and steering is in the way your measurements are probably more like 4 o'clock and the front is like 10 o'clock. If you mark your tires and then roll the quad you're going to get the same measurement. Also after you make any adjustments to the steering arms you have to roll the quad forward one revolution all over again, then measure again.
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
Ridgebackguy86
Sep 19, 2015 12:48 PM
atvcollector
Sep 8, 2015 05:11 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Logan Collins
Sep 5, 2015 08:03 PM
