Warrior tire size
Old Jan 10, 2002 | 12:10 PM
kuz28's Avatar
Hey folks, can some one tell me what size the stock tires are? the Latest DW has specs on the warrior in two diffrent areas with diffrent tire sizes. I'm looking to purchase a set of ITP xct holeshots and need to match up the sizes.
Old Jan 10, 2002 | 05:02 PM
YellowTRX400EX's Avatar
The stock front are 23-7-10 and rear 22-11-9
Old Jan 10, 2002 | 05:12 PM
1BadWarrior's Avatar
Not unless they have changed the tire size since the 99 model year(which is highly unlikely) the stock tire size is front 22x7x10 and the rear 22x10x9.
Old Jan 11, 2002 | 01:37 AM
ridnwarrior's Avatar
Don't go by the stock tire size in determining what tire size you need for your quad when buying replacement tires.
Stock tire diameter is 22" but if you run motocross you need a 20" tire in the rear and 22" in the front. If you run trails then ground clearance is an issue. Stick with the 22" diameter. The stock width in the rear is 10" but most aftermarket tires come in a 11" or 12" width for a reason. Figure out what type of riding you do, then figure out what kind of surface you run on then you can make a tire choice.
Bratman2
Aug 6, 2022 01:42 AM
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
Aug 6, 2015 05:29 PM
