Raptors&Warriors
Old Jan 11, 2002 | 02:12 PM
kuz28's Avatar
okay guys. here's a new one. i own both and i'm in the middle of buying tires. i would like to purchase a set of 22" holeshots w/rims for the warrior. i'm thinking about going with raptor stock offset on the rims so i can use them on my Raptor for the trails.
if this widens the warrior so be it. it could use it. opinions please.
i also plan on ordering a set of 20" holeshots to replace the raptors stock tires. As well as a set of ice tires for both Machines.
Old Jan 11, 2002 | 02:38 PM
bigaqua's Avatar
go with razors thats what i got[img]i/expressions/face-icon-small-shocked.gif[/img]on my raptor and warrior
Old Jan 11, 2002 | 02:49 PM
kuz28's Avatar
I do like the razors but they don't last as long as ITP's. Great tire for racing but not practicle for everyday use. atleast not on my budget. i'm looking at $1200 in tires and rims these things need to last.
a women at rockymountain atv said the offset is the same for both quads. Can anyone confirm?
Old Jan 11, 2002 | 03:27 PM
ridnwarrior's Avatar
Can you put a stock set of Raptor rims on a Warrior? Do they match up?
I think the Warrior is 156 mm correct?
Old Jan 11, 2002 | 05:32 PM
FISHER1648's Avatar
Ive got both bikes as well. The wheels are interchangable between the two. It's real nice especially when you get a flat and want to ride - just swap. I run 22" dia rear tires on my warrior with good results. I also use 22" holeshots on my Raptor (primarily for the added ground clearance). You probably already know the sizing standards, but if unclear, check www.yamaharaptor.com tech tips for a good write up on tire size.
See ya,
Old Jan 12, 2002 | 05:11 PM
skramblr's Avatar
I have my Raptor paddles mounted on a set of my Warrior rims. You just have to flip the rims around backwards (IE, valve stem is on inside of rim instead of outside). They work fine.
Old Jan 12, 2002 | 05:41 PM
Why do you have to flip the rims around to the other side? Is the Warrior offset different than the Raptor offset?
Old Jan 13, 2002 | 03:01 PM
skramblr's Avatar
Yes, the offset is reversed between my Raptor rims and Warrior rims. I also noted that the Studs on the Raptor axles are about 1/4" taller. This could spell trouble for using Raptor Wheels on a Warrior if the mounting flange is too thick.
Old Jan 14, 2002 | 06:34 PM
I understand what you mean but that is my problem. I know you can use Warrior rims on the Raptor but can you use Raptor rims on the Warrior is my only comcern. Let me know.
Old Jan 18, 2002 | 11:47 PM
skramblr's Avatar
Yes, the Raptor rims also fit on the Warrior. With valve stem out, Warrior has a wider stance. With valve stems in, It's same as stock.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
