Stock Banshee head, How much can I shave off without clearance problems?
Old Jan 13, 2002 | 11:42 PM
No2StrokeBs's Avatar
I recently took 30 thousands off of a friends 98 Shee, I had about 10 thousands more to go before I got into the domes. I have been told that I can take off as much as 80 thousands without clearance problems. Anyone want to conferm this? I dont want to scrap a friends perfectly good head.
thanks guys
Old Jan 15, 2002 | 08:39 PM
Come'on guys, tell that someone here knows
Old Jan 15, 2002 | 10:06 PM
Backcountry's Avatar
What fuel are you going to use? Are the cylinders ported? What type application? .030 on stock cylinders, on pump gas would be about as far as I would want to go......
Old Jan 15, 2002 | 10:36 PM
Its not the fuel or detonation that concerns me, I have access to VP Blue,so the fuel is not a problem. I am worried about piston to head clearance. I have took 30 thousands off a number of Banshees, and unless they are in extremely high alitutdes, 93 octane is usually sufficent, anyhow, thanks for the reply
any other thoughts?
Old Jan 16, 2002 | 12:45 AM
Your minimum safe squish clearance pretty much regardless of octane in that bore size would be .030-.032" Most shoot for a target of .035"
However with a stock squish its a tad on the wide side for that tight of a squish clearance...watch the RPM...
Old Jan 16, 2002 | 09:29 AM
garyc660R's Avatar
Also, if you go too far with the lathe, the head should be "re-chambered". .030 is a good, conservative # too shoot for. Call around.....some engine builders don't like much more than that because you start too loose some high RPM revs with additional compression.
toonces
Oct 16, 2019 12:11 PM
Stillonit
Aug 5, 2015 07:46 PM
traumajunkie
Jul 5, 2015 03:03 PM
ranvette
Jul 4, 2015 06:13 PM
B4NSH333
May 26, 2015 06:55 AM
