blaster carb
Old Feb 8, 2002 | 08:18 AM
tom18801's Avatar
im working on trading my thumb throttle for a twist throttle that dosnt have that switch on the carbuerator can i make my thumb throttle work without that switch to
Old Feb 8, 2002 | 11:45 AM
blaster29's Avatar
More info please...
Old Feb 8, 2002 | 03:22 PM
SR2's Avatar
SR2
Im the guy thats going to trade him my twist throttle for his thumb throttle. Okay heres the story: His blaster and all stock ones have this switch assembly on the carb were the cable goes into first then into the carb itself. Now on my blaster that switch is missing, instead the cable just skips it and goes directly into the carb. The thing i would like to know is if i put on a stock thumb thottle do i need that switch to make it work? Im almost sure that his will work fine without it because my quad is running fine without it right now. Tom if your really interested in trading, i think the best thing to do is just to trade everything from the trottle all the way to the carb. Unless someone knows different. thanks for your help guys.
Old Feb 8, 2002 | 03:38 PM
blaster29's Avatar
That switch is probably part of the T.O.R.R.S. system. You can remove that all together, and the bike will run fine. I haven't done this so I could be wrong... But your friend has a good idea and trade the entire assy..
Old Feb 9, 2002 | 01:21 AM
Blaster96's Avatar
GET RID OF THE TORS!!! After having many problems with my blaster, i disconnected the TORS and it ran fine. NOthing will happen to the blaster with it disconnected. Dont worry about swapping out the TORS. You can get an idel kit from motion pro. Both blaster will run fine with out the Horrid TORS hooked up.
Frisky2050
Apr 9, 2020 11:19 AM
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
joeyupton
Jul 14, 2015 11:51 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
