Engine Assembly?
Old Feb 12, 2002 | 09:33 AM
ZRWHAT's Avatar
Anybody use yamabond or other silicones when assembling their engines? The manual doesn't call for it, but I found quite a bit of it in the engine when I tore it apart. Thanks.
Old Feb 12, 2002 | 10:30 AM
THEMOOSE's Avatar
I prefer Copper Coat, After many years of building Volkswagen engines I have found it applies easy, seals well, easy clean up on disasembly. Silicones even if applied correctly gets into the engine when the halves are torqued together & squeezes the silicone out. Remember when you wipe the excess from the outside of the case the same amount is on the inside. So if you use silicone change your oil & filter after every couple of rides until you can cut your filter apart & see very little silicone or it could clog your filter.I've never used yamabond so I have no opinion on it. Use Copper Coat or something similar like Gascinch & you will have a good seal & less headaches. [img]i/expressions/face-icon-small-happy.gif[/img]Whatever you use follow directions & don't use more than needed or you'll have a hell of a mess on the outside & inside of your engine
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Aitch
Jul 21, 2015 09:40 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
