Replacing my Banshee rear axle
Old Feb 13, 2002 | 09:41 AM
RoostKing's Avatar
I am getting my new/used axle today and need to know what the procedure is for getting the bearings that are on my bad axle off. Only the right side one is currently on the axle. It may be that I can just pull them off, but I am runniung out of time so Id like some tips/tricks before I start this tonight..
Thanks!
RoosKing...
Old Feb 13, 2002 | 08:51 PM
54warrior's Avatar
Let me get this straight: the bearings are on the axle, not in the hub, correct? I know when I replaced the bearings on my warrior for the first time, they were siezed in the housing, and had to be pressed out. It was a real pain in the @$$. But if i understand you correctly, the axle came out fine, except one of the bearings won't come off the axle. But if you have a completely diff. axle to put in, it's no big deal, as long as you aren't gonna try using the old bearings again???? I wouldn't recommend that.
Good Luck.
rcappie4
Jul 10, 2015 04:54 PM
cSchwartz
Jul 9, 2015 02:40 PM
Jul 7, 2015 11:00 PM
Rider252
Jul 6, 2015 03:37 PM
