Why does my clutch slip only at WOT??
I can't figure out why it does this. To me if it were truely the clutch disc slipping wouldn't it do it when I climb steeb inclines?? It only does it if I'm WOT for a long time or if I take a real tight turn WOT and my rear tire hit the berm. Can anyone explain this to me?
At extended WOT you have a extended load that is building a lot of heat that can cause your clutch to slip. When you hit a berm you are creating a shock load that can cause your clutch to slip. I believe these are early warning signs that your clutch is ready for replacement. It'll probably start getting progressively worse.[img]i/expressions/face-icon-small-sad.gif[/img]Also I heard some automotive oils have additives that can affect clutch performance.
Jeff Roper
Feb 1, 2022 11:48 AM
