What needle groove?
Old Feb 17, 2002 | 11:37 AM
wshrdskin's Avatar
What needle groove is everyone using with their full pipe (not slip on) and filter mods, foam or K&N? Just curious. [img]i/expressions/face-icon-small-smile.gif[/img] According to Alba (the full pipe i have) its 5th groove from top for me. Seems ok. Thought I might try 4th and see if it makes a difference. Got a tannish color on the spark plug so mixture seems ok. TIA
Old Feb 17, 2002 | 02:25 PM
wshrdskin's Avatar
6 views and nobody wants to say what groove they are running?
Old Feb 17, 2002 | 02:51 PM
Sandgod's Avatar
We're running fourth spot here at 5000ft and it helps. I hear it helps even more at sea level. The 5th spot seems kind of over-kill.
Old Feb 17, 2002 | 05:38 PM
wshrdskin's Avatar
Overkill is what i'm thinking also. Thanks for the comment.
Old Feb 17, 2002 | 09:20 PM
14mins's Avatar
What fuction does the needle position serve? I have read different people in here, with the same mods use a different number with the same elevation. I know first hand that it makes a big difference on a ds650. Thanks.
Old Feb 17, 2002 | 09:25 PM
RaptorRidingOut's Avatar
The needle serves 1/4 to 3/4 throttle...I run on the forth clip Dynojet kit.
Sandgod's Avatar
Your needle is for 1/4-3/4 throttle. Mains are for top end and pilots for just off idle. Of course all these jets over-lap into the next area of rpm then sign off and have no impact at all.
Old Feb 17, 2002 | 10:46 PM
14mins's Avatar
So raising or lowering the needle makes the fuel ratio rich or lean? Thanks
Old Feb 17, 2002 | 10:49 PM
Sandgod's Avatar
Raising the needles richens it up (hence lowering the clip)....
speedbuff
13
Nov 11, 2020 10:16 AM
Dammar
Apr 20, 2016 06:03 AM
wrencher82
Sep 24, 2015 03:39 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
WilliamBos
Sep 6, 2015 10:53 AM
