Need help on idle problem on 01 Raptor
Old Feb 18, 2002 | 12:29 AM
Raptoman660's Avatar
For some reason or another,my Raptor runs rough at and idle. I put on a White Bros pipe and K&N filter. When I run it at half or full throttle it is fine,but at a idle it sounds like it's missing. I changed the jet's to 146 on the left carb and 150 on the right. I still has that problem. If anyone has any idea's,I would greatly appriciate it..
Old Feb 18, 2002 | 07:53 AM
rraptorr13's Avatar
Have you changed the filter set up yet ? If so the needle clips could be set to low. I know that the instructions say to put the clips in the forth position but the guy at dynojet (who make the the K&N jet kit) said to go to the second position with the clips. Try contacting Dynojet, K&N, or White Bros.
Old Feb 18, 2002 | 08:57 AM
garyc660R's Avatar
<< I changed the jet's to 146 on the left carb and 150 on the right. I still has that problem >>
You did'nt mention if you were running a Dyno-jet kit....are you? The main jet's are not gonna take care of an idle problem. What size pilot jets are you using?
<< I know that the instructions say to put the clips in the forth position but the guy at dynojet (who make the the K&amp;N jet kit) said to go to the second position with the clips >>
Rraptorr13....What was wrong/symptoms with your machine for the Dyno-jet guy to prescribe moving the needles down (effectively leaning this circuit)?
Old Feb 18, 2002 | 05:53 PM
No I'm not running the Dyno-jet setup. But that is a good point on the pilot jet. Also could a bad coil be the problem? I'm not for sure if I were to change the pilot jet.
Old Feb 19, 2002 | 07:41 AM
rraptorr13's Avatar
It was a little rich. Plus it didn't want to idle when you slowed up . Example tight turns , coming off a jump with little room after landing
Old Feb 19, 2002 | 05:13 PM
Raptorrider2001's Avatar
Check the carb boots to see if they are backing off. Also, look very carefully for tears or cuts around the clamp areas.
Old Feb 19, 2002 | 08:01 PM
RAPTORMEAN's Avatar
air/fuel mixture screws!!! sounds like you didnt touch them..try turning them to the right until they stop (NOT TIGHT JUST UNTIL THEY STOP) back them out 3 turns put your needle back at 4 slots down
Old Feb 19, 2002 | 08:04 PM
RAPTORMEAN's Avatar
ohh and check your e-brake set up
Sjrpp
May 2, 2023 03:59 PM
hugemoth
Jul 20, 2020 03:28 AM
Sjrpp
Nov 15, 2019 09:59 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
yambam13
Jul 4, 2015 01:49 PM
