trouble with blaster!!
Old Feb 20, 2002 | 07:02 PM
BlasterMan13's Avatar
im having trouble with my 2001 blaster..ok i get in top speed then it like lacks speed and doesnt seem to go that fast it dies down a little bit it seems like ....then if im in 3rd gear it will do it once in awhile....what can be the problem????? has anyone had this problem??????????????????[img]i/expressions/face-icon-small-mad.gif[/img]
Old Feb 20, 2002 | 08:02 PM
yamahagye's Avatar
maybe you need a new plug. One or more of your jets may be clogged. The airfilter could be dirty. The jetting could be off. Timing may have retarded itself too much and won't run well at high RPM's. fuel line may be clogged and won't let enough fuel to the carb.
JaMeS
Old Feb 20, 2002 | 08:24 PM
okay..but how do i clean the air filter?? just put it in oil or what?? and how do i unclog the the fuel line
Old Feb 20, 2002 | 08:25 PM
k what one of those plugs should i get at moto man under ngk???? for a 2001 blaster? what one will be the best or what one should i get?
Old Feb 21, 2002 | 12:20 AM
yamahagye's Avatar
To clean the filter, i'm assuming it has a foam filter on it, just soak it in a container of gas. Then squeeze the gas out of it and then soak and squeeze again. NGK makes good spark plugs. If you want to check your gas line, disconnect it from the gas tank and the other end from the carb, get an air compressor and blow air down the line. Make sure the filter was on properly or you could have sucked dirt into the motor and damaged your reeds. The owners manual should have details for cleaning the air filter and re-oiling it. Is the filter a paper filter or foam filter? Your dad could probably tell you if you are not sure. If it is a paper filter, you can just blow the dust out by blowing on the thing with a leaf blower or air nozzle. and also, if it is a paper filter, DO NOT OIL IT.
JaMeS
Old Feb 21, 2002 | 07:54 AM
ok its a foam filter so i just put it in gas?? and what spark plg shoul i buy at motoman under NGK??
Old Feb 21, 2002 | 05:04 PM
hey yamahaguy can u reply to my question at soon as possibe!! thanks
Old Feb 21, 2002 | 10:36 PM
yamahagye's Avatar
soak the filter in gas and squeeze as much as the gas out as possible. Do that 3 or 4 times and let the remaining gas evaporate off the filter. I don't know what kind of plug the blaster has so just ask for a plug that fits a blaster.
JaMeS
Old Feb 21, 2002 | 10:39 PM
yamahagye's Avatar
P.S. spray the inside of the carb with carb cleaner (any brand). And i forgot to mention, oil the filter before you install it.
JaMeS
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
Clint Russell
Sep 25, 2015 03:20 PM
nastyblaster100
Sep 13, 2015 01:19 PM
