Raptor oil tank over-fill ??
On the right hand side of the machine on the jug there are 2 bolts 1 allen head and 1 phillps. The lower one (phillips head) is used to check engine oil pressure. It might be messy to do this way. the other option drain the tank. Put a quart in and keep adding till its right. No the oil tank is not a over flow its under pressure.
FISHER1648,
Heres what I do and the oil level is up on the stick.
After oil dump
able to put in oil tank = one and three quarters quarts of oil
start motor let oil circulate and shut off engine
add to fill reservoir again and start motor again and then shut off and check
the amount that I put in is 2 qts. and 12 ozs
Chet
After oil dump
Chet
The yamaha shop manual calls for 2.06 us quarts with an oil filter change.. 2.01 quarts without an oil filter change.
Note: the dipstick should be measured with it **NOT** screwed in (per the yamaha shop manual)
It's also specific that you should add 1.8 quarts of oil, start the quad, 3 revs on the motor, stop the motor, then add the remaining .26 quarts of oil.
You should also make sure of 2 more things (according to the yamaha shop manual)..
The engine and oil need to be at operating tempature..
Wait a few minutes after stopping the motor to check the oil level..
Just repeating the shop manual (the one from yamaha)
Brad
Brad
Alex Rodak
09-13-2015 12:30 AM
Alex Rodak
09-12-2015 09:39 AM
Alex Rodak
09-11-2015 11:42 PM
