Two Stroke Advantage?
Old Feb 28, 2002 | 03:47 AM
prs311's Avatar
What do you feel is the advantage of a two stroke against a four stroke. what do you feel the disadvantage is besides changing top ends and mixing oil and gas?
One weird question, when your going down a hill on a two stroke, can you let the gears hold you back like a 4 stroke, or will it kinda foul out or something? Just curious
Old Feb 28, 2002 | 04:27 AM
elsancho's Avatar
in general your mods are going to be cheaper,and as well there power-weight ratio is phenomenal
Old Feb 28, 2002 | 11:31 AM
CBUS660R's Avatar
The motor is also more compact, allowing for a lower center of gravity and better weight distribution. Disadvantages would be they tend to have less low end torque and the power curve can be harsh when the engine gets "on the pipe" which can cause problems in low traction or uphill situations.
exmotocrosser
Sep 13, 2019 06:12 AM
exmotocrosser
Sep 26, 2015 08:18 AM
BYC
Sep 25, 2015 02:10 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
