HELP!!!!! Broke bolt off that holds clutch spring in on Raptor
Old 03-10-2002 | 01:55 AM
MEAN1's Avatar
I broke the bolt off in where the clutch springs go in to. Tried to drill it out. RUINED IT!! My manual calls it a CLUTCH BOSS is this the same as a clutch basket. If so then is that what Hinson Racing sells. I would much rather replace it with one of those, but I don't want to order one and it not be what I'm looking for. Can some one help me PLEASE!!!!
Old 03-10-2002 | 01:29 PM
vilnrk's Avatar
I think you would call that part of the clutch assembly the inner hub. There are three main parts to the clutch , the outter (clutch basket) , the inner (hub assembly) , and the pressure plate. I have broke off bolts also in the same situation. Not really much you can do about it. I use an impact wrench to take the nut loose to remove the inner hub. Don't use anything in between the post to hold it from spinning , the posts will snap off if you do. Go to napa and buy a left hand drill a little smaller than the bolt. Sometimes the left hand drills will make the broke off bolt unscrew itself as you drill it. Good luck. [img]i/expressions/face-icon-small-smile.gif[/img]
brad wheeler
07-14-2015 12:19 AM
Countrygirl1976
07-13-2015 11:08 AM
coolguy420
07-10-2015 02:17 AM
Wnthunting
07-09-2015 04:02 PM
Jkfx400P
07-06-2015 11:04 AM
Quick Reply: HELP!!!!! Broke bolt off that holds clutch spring in on Raptor
