Backfireing
Old Mar 12, 2002 | 12:09 AM
CCRERaptor's Avatar
this may have already have been posted before but i kind of need to know. every now and then when i am riding my raptor will back fire. it seems happen when i am really on the gas and right when i let off i back fires. it only does it when i let of quickly if i let of slowly it won't happen.any ideas
Old Mar 12, 2002 | 12:21 AM
SheeMan's Avatar
Check out the Bombardier area, someone put up the same post, and some people have replied with usefull information.
Old Mar 12, 2002 | 12:25 AM
wshrdskin's Avatar
Adjust your fuel/air mixture screw. Turn it out 1/4 turn at a time till the backfiring stops. With my mods listed below my screws are set at 3 turns left carb 3 1/4 turns right carb. These adjustments are turns out from a fully closed (seated) position on the mixture screw.
Old Mar 14, 2002 | 10:54 AM
garyc660R's Avatar
If opening the mixture screws does'nt clear the problem up, you will have to install larger pilots.
ReconBayou
Oct 31, 2022 05:37 PM
fordfaithful21
Dec 7, 2015 05:52 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
alzgarvin
Sep 11, 2015 08:53 AM
Brandon400
Sep 7, 2015 12:20 PM
