What Bars for a Raptor?
Old Jun 1, 2002 | 01:47 AM
ltracerx's Avatar
I agree, go with a Bar that is a little higher quality. I really liked my Pro Tapers on my CR. Never bent them and I laid it over quite a few times. I think if you want a tall bar, try and get a Quadracer bend, if I remember correctly, they are taller bars.
Old Jun 1, 2002 | 11:25 AM
Raptor690's Avatar
I Run Renthal CR 500 medium rise on mine ...you also have to think about what you want to have on your steering stem ...do you want to keep the stock housing or go with an aluminum handle bar clamp? you have to get a higher rise bar to clear the stock key/idiot light housing...even with my medium rise bars you can't get the pad and stock housing on at the same time and still have the bars where you like them , but with the UMI handlebar clamp I have, you have no problems with clearance ..you may even get low rise bars on there with the pad and aftermarket clamp
Old Jun 1, 2002 | 12:24 PM
warrior007's Avatar
The trottle cable may have to rerouted to work with higher rise bars. I know my buddy with lonestar steering stem had problems. the cable is pretty short so I would keep it conservative..
Old Jun 1, 2002 | 12:41 PM
eRAPTOID's Avatar
Hey RAPTRMAN - can you provide me with a pic of your bars? I have the '01 Raptor and the bend is different from the '02. Which one do you have? Cause I want pretty much the same bend as what I have now but with the crossbar too.
Old Jun 4, 2002 | 11:22 PM
  #15
raptrman's Avatar
sorry eraptoid I don't have a dig cam or scanner but they are just the same as the stock with the cross bar. I had my 01 raptor stolen and I now have an 02. They seem to have the same bars. Sorry I couldn't help more.
Old Jun 4, 2002 | 11:32 PM
  #16
velocityraptor's Avatar
I myself have the Fly Aero Tapers and I love them.
Old Jun 5, 2002 | 12:32 AM
  #17
THEMOOSE's Avatar
I'd like a bar that is a little taller, slightly wider, uses the stock size perch & no crossbar.
Which bar would I need?
Old Jun 5, 2002 | 01:10 AM
  #18
desracers's Avatar
Hey Moose, get the protaper bar with the high rise bend. I go the CR hi bend and no problem for me. it pretty comfy for me to ride w/ that bar.
In my opinion it the best bar you can get.
Bill
Old Jun 5, 2002 | 01:25 AM
  #19
THEMOOSE's Avatar
I thought the pro tapers used a diffrent size perch?
I have the Trail Tech computer & lights mounted on my perch & want to use the same one.
Old Jun 5, 2002 | 01:37 AM
  #20
desracers's Avatar
well sratch that one out, unless you still want to switch over the and go order new one after you look up the site. your call..... just trying to help you out.
Even I got one it mount just the left side from the center since I have GPR on it.
http://www.trailtech.net/atv.htm
bmxatv10
Oct 14, 2022 06:23 PM
wendal
Sep 7, 2019 06:46 AM
badgerboy1
Sep 26, 2017 06:11 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
black_thunder
Sep 22, 2015 07:59 PM
