changing oil in blaster
Old Apr 25, 2002 | 06:47 PM
  #21
ElemEn0hpey's Avatar
A Little Tip:
In Sand, Use Sand Tires.
PS~ They Help!
(JK)
Old Apr 25, 2002 | 11:49 PM
  #22
2fun's Avatar
As I said before, this has already been gone over. Read here:
http://216.33.148.250/cgi-bin/linkrd...eadid%3d301806
This link does not seem to be working, so I bumped the subject up to the top in the Honda forum. Click on the thread titled:
What is the difference between atv/cycle oil and auto oil?
Old Apr 26, 2002 | 11:55 PM
  #23
YZFBANSHEEKING's Avatar
Start your Blaster and let it warm up for several minutes first to warm up the oil in the engine then shut it down and find the bolt on the bottom on the engine. You take it out and the oil comes down out. Put a pan under there and then to fill it up again there is a little bolt with a wing on it on the right side of your engine. Right behind the kickstarter. That is where you put the oil back in.
If you now look, I'm not sure but I believe it's behind the kick starter you will see a glass circle ( it's the size of a quarter ) after you warm up your Blaster shut it down and look at the glass circle, there is a mark on the circle, if the oil level is below the mark add more oil, if the oil level is at or above the mark, DO NOT add any more oil as it will have enough. Congrats you have now changed the oil in your blaster.
Here is a reminder use the Yamaha lube oil it has worked great in my wife's 00 Blaster, and I recomend it.
Any questions about the Blaster Email me..
As for needing a new manual for your Blaster e-mail me and I will give you a number for you to call Yamaha to receive a new manual for free.
HOWELLYZF@AOL.COM
Old Apr 28, 2002 | 02:23 AM
  #24
RC350's Avatar
On the right side of the Blaster engine, near the spot where the oil goes in, is the amount of oil that should go into the crankcase when changing the oil.
This amount is 650cc's of oil. It probably is listed as 650cm3, which is the same thing.
However, in my Son's Blaster, I put 700cc's of oil at the recommendation of the local Yamaha service department.
The oil I use is Bel-Ray gear saver oil 80w, which is made for two stroke transmissions/wet clutches. Don't let the 80w rating fool you, since this is a viscosity rating for gear oils which is essentially the same as a typical 10w-40 motor oil.
In the past, I have also used Yamalube, but prefer the Bel-Ray.
Regards,
Rog
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
nastyblaster100
Sep 13, 2015 01:19 PM
bigbear350quad
Sep 11, 2015 12:40 PM
Jason Campbell
Sep 7, 2015 02:25 PM
Elkaholic
Sep 6, 2015 02:44 PM
