yamaha banshee drain plugg.
Old Apr 29, 2002 | 08:59 PM
clunk96's Avatar
recently bought a 2000 Yamaha Banshee... the drain plug stripped. (not the plug, but the engine itself.)
What do you suggest I do to repair this?
Old Apr 29, 2002 | 10:28 PM
wshrdskin's Avatar
Try re tapping the hole with the same size tap. If this doesn't work for you, then you may have to go the next size bigger and find a different bolt. I'm not sure but I think there are rubber plugs you can buy that when tightend with the nut the expand against the sides of the hole. Where to get those I don't know. Maybe a plumbing store. ??? Check with your dealer to see what they have. JMO
Old Apr 29, 2002 | 11:44 PM
Ryan99's Avatar
I had the same problem on mine. i had to take the motor apart. If you look in the hole for the drain plug you will notice only a few threads on one side were a channel is cast into the lower half to drain it completely. Mine actually had a crack in the chanel leading from the drain plug hole. One of my friends at a machine shop welded the hole shut and filled the channel. then he drilled and tapped it for standard 1/2" threads. No problems with mine now. I can change my oil without worrying about stripping the hole and cracking the case. But the channel is all welded up to. I might not get the last drop of oil out but its fixed.
Old Apr 30, 2002 | 11:09 AM
clunk96's Avatar
Wont the rubber plug be affected by the oil? Won't it 'swell' ?
Hmm... I really don't wanna have to take my whole motor apart... I only rode it once =(
I was thinking of heli-coiling it, or taping it to an oversized, but... I don't know what size the hole is.. I hate metric.
Oh- btw... I see the 'notch' in the threads, but, there's also a hole on the other side... anyone know what thats for?
If I heli-coil it... these ports won't work anymore, and I just wanna make sure that it's okay.
greek271
Aug 8, 2015 08:16 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
Shifts
Jul 3, 2015 07:59 AM
