Base Gasket Is Leaking why??
Old Mar 1, 2000 | 09:36 PM
fastrblastr's Avatar
On my blaster the base gasket is leaking and I can't figure out why it is doing it. This is the second gasket to go bad. It is correctly torqued so if someone could help me please I would appreciate it.
Old Mar 1, 2000 | 11:20 PM
1BadBanshee's Avatar
well, the only other possibility if the gasket was not defective (which i am assuming after two they are not) and you torqued them properly, is that the jug and/or the case is not true (flat). Those are the only real options that I can think of.
Old Mar 2, 2000 | 01:54 AM
hittinhard's Avatar
Blasters have problems with blowing gaskets....I dont know why....Ive had your problem happen twice and the right side cover gasket always needs replaced each year....I heard you can make SMALL holes which combined with propper gasket sealer will keep the gaskets from comming out....I never tried it though
Old Mar 3, 2000 | 09:31 AM
vmaxer's Avatar
check to see if crank case surface is smooth where case halfs join together where your gasket sits Also there is a updated cluth cover gasket ,if your side cover is leaking. vmaxer.
exmotocrosser
Sep 13, 2019 06:12 AM
EIF
Apr 20, 2017 07:15 PM
tysonbully
Sep 28, 2015 02:30 AM
wrencher82
Sep 24, 2015 03:39 PM
