99 Warrior left in the snow.
Old May 4, 2002 | 06:13 PM
SSports578's Avatar
I forgot to put the four wheeler in the garage when I got home and It snowed on it. Now when I start it it won't rev up. It idles fine but when u try to give it some gas, the engine knocks and it stalls out. I checked the carb and put new gas in it, any help would be great!
Old May 4, 2002 | 07:21 PM
perrya's Avatar
My warrior does the same thing!
all i do is pull the choke all of the way out, let it warm up, push the choke in and head for the trails.
usually if you are starting a cold engine it will take a wile to get going. If your problem still occurs after the engine is warmed up i
really don't know what the problem is.
Old May 4, 2002 | 10:49 PM
SSports578's Avatar
The Problem still occurs after the engine is warmed up.
Old May 5, 2002 | 02:07 PM
A2000's Avatar
Check your parking brake adjustment. Sounds weird but it could be your problem.
Old May 5, 2002 | 07:22 PM
Gramps's Avatar
I would check or change the spark plug and drain the float bowl
on the carb. If you had water in the fuel it will stay in the bowl
a long time .
Old May 8, 2002 | 08:52 PM
perrya's Avatar
SSPORT578
i just had that same problem with my warrior and it was the rev limiter.
the connection to the parking brake was loose all i did was push it in and my problem stopped
Hope this helps. reply if you get it fixed.
buddieboy
Dec 9, 2016 05:50 PM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
2many2ride
Sep 27, 2015 04:35 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
