How exactly do you start a blaster?
Old May 5, 2002 | 08:45 PM
yamablaster's Avatar
Can you tell me step by step?
Old May 5, 2002 | 08:51 PM
KNOWSALOT's Avatar
The Facility
[1] Be sure the fuel petcock is in the 'on' position
[2] Be sure the switch on the left side handlebar is in the 'run' position
[3] Turn the ignition key switch to the 'on' position
[4] Pull up on the choke **** on the carburetor
[5] Might have to give it a little throttle [depends on the tune]
[6] Be sure it's in Neutral
[7] Kick it
Old May 5, 2002 | 11:54 PM
2fun's Avatar
Don't forget to make sure there is gas in the tank.
If the oil pump is blocked off, make sure there is oil mixed in with the gas.
Old May 6, 2002 | 02:04 AM
Blastermaster's Avatar
ypu don`t even have to put it in neutral just pull in the clutch and kick
Old May 6, 2002 | 07:12 PM
warrior350megamax's Avatar
is it supposed to be real hard to kick start a 4 wheeler when youre in gear w/ the clutch in? my sisters friend got one for her son and its near impossible to start that thing when its in gear w/ the clutch in(it doesnt want to turn over, really hard to kick it) is this a problem or am i a total idiot?
Old May 6, 2002 | 08:00 PM
KNOWSALOT's Avatar
The Facility
It depends on the clutch adjustment. One adjusted loose will be hard to crank in Neutral....if it cranked at all. If adjusted tight, It's not going to be a problem.
If I'm not sure, I put it in Neutral.
Besides, if someone is asking how to crank one....I do believe it's a safe bet that they should be in Neutral.
Old May 6, 2002 | 08:03 PM
Alien660r's Avatar
when its cold it will jump on yaa....but if its a blaster it should crank in any gear....all they need is mixed gas and love and there ready to kick a$$ and take names...if its not a blaster ...well...inlighten us people?
Old May 6, 2002 | 10:07 PM
NotuRaptor2's Avatar
warriormegamax,
Even with a properly adjusted clutch, it can be harder to kick start in gear if the engine is cold. Once it warms up you should be okay. I have a Raptor and always make sure it is in neutral even with the electric start. The bike will jump forward a few inches if I try to start it in gear with a cold engine. The same was true for all 6 of my Yamaha MX bikes.
/NotuRaptor
Shooterj2003
Jun 21, 2015 09:02 PM
1000gade
May 27, 2015 12:37 PM
B4NSH333
May 26, 2015 06:55 AM
littleatvr
May 18, 2000 07:45 PM
dunc_n
Aug 26, 1999 09:32 PM
